Dryer makes squeeking noise at first start up and while running as it heats it stops
Hello,
I have this GE Profile Dryer Model# DPSQ475ET4WW as it starts up drying cycle it squeeks real bad as it heats up. As the cycle runs to dry it still has the sqeeking noise but not as loud as it is when starting up. Have no owner manual with this dryer, would like to fix this dryer myself with instructions shown and obtain parts to fix the problem and how much cost we are talking to replace. Please help my problem!!!
[LEFT]Thank You,
Elaine Mohr
ecttmohr4@att.net[/LEFT]
The most common squeeking on a GE is the rear bearing, part #AP2619300
You will need to raise the top, remove the front panel and the drum to get to it.
Nat
Thank You for the info and the help on how to get to the part that needs to be fix. I will try to conquer this myself without high cost of sevice repair person.
Thank You,
Elaine Mohr
Keep us posted.
Nat
