dryer makes a very loud noise while in use. almost like its falling apart. I think it may need a new belt but not sure if that could be all thats causing the problem.
Hi Trish
I doubt if the belt is your problem, more likely your rollers (if you have them) or your idler assembly.
I cannot get your model to come up, and I see you are having washer problems also. These are pretty old machines and I think it is probably time to go out and get a new or good used set rather than put time and money into machines of this age.
