my dryer makes a loud noise. it still seems to heat and i think the drum is still turning
A model number may help others help you.
Also you need to give a better description.
Is the unit heating?
What does the noise sound like?
Where is it coming from?
Is the drum turning?
Does the drum rotate fairly easily when turned manually?
