My dryer is heating normally but, my clothes are still damp i have to put it like 2 or 3 times but it still damp a littlebit, do you knwo what could be the problem? Ive checked on this website the section not heating, but mine is heating is just not drying my clothes. please help.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer’s vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
