Dryer is doing nothing
Dryer was working fine, opened it to add clothes, shut the door and hit start and now nothing is happening. Any help?
Any noise at all when you hit the start button? If it’s completely dead, make sure you check the house breaker. From there you should probably check the thermal fuse which is located on the blower housing. If it popped it will give you a completely dead situation. Below is a picture of what it looks like.
AP6008325
