I need to know how to get the back panel off so that I can replace the orifice. Do I have to remove all the screws from the back panel or is there another way you are suppose to get into the motor
What is the original problem with the dryer?
Hi Gene,
I am trying to change the dryer from propane gas to natural gas. I have the orifice to put on the dryer but i cant get into the back of the dryer to put the part on.
Hi Gene,
Sorry if i did this wrong.. this is the first time ive used this website
You can not do it from the back. You have to remove the front panel.
Here are the breakdown diagrams and Replacement parts for INTERNATIONAL LNC8766A71 | AppliancePartsPros.com
