Dryer Heating Element wont shut off When Dryer vis off
The heating Element stays on even when the Dryer is off.when this first started the dryer didnt want to stay running and then the heat element started staying on so I have to shut off the power and when I turn it on it gets extremely hot.What is the trouble?Thank You for any help
Replacement parts for Whirlpool GEW9878JQ1 DRYER | AppliancePartsPros.com
Sounds like you have a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time.
