Hello,
I was reading your forum and I have a similar problem with my w/d. My machine just will not power at all. I turned off the fuse box outside and back on again and the machine worked! For only 2 seconds.. then back to no power again. No matter how many times i turn the fuse box on and off again nothing works. I did some google research to find out the issue but it seems that I might need one of those meter readers for power testing, which I don’t have. All I could come up with was the fuse might be faulty so I unscrewed the metal plate in the back near the power cord and all I saw were wires connecting to the power cord. No fuse. I am trying to avoid the maintenance man coming cause I have no money to fix this issue. Is there a way I can fix this problem without that meter machine? All help is much appreciated thanks so much!
:eek:
