Dryer f23 error code
I have a WP model # wed9600ta1 and checked the resistence to the fuses and all turned out fine. What else can it be-its a steam dryer and is there a water temp sensor that might be causing the problem?
Ed, The F 23 error code indicates a fault in the exhaust/outlet thermistor.
AP6013514
You would want to access the main control board, on the left side of the cabinet , under the top and disconnect the P4 connector. You’ll need to check for 10,000 ohms resistance across pin P4/pin3(Red) and P4/pin6 (Red) in the harness connector. If all’s OK, you’ll need a control board
AP6016287
[model]wed9600ta1[/model]
[ATTACH]4402[/ATTACH]
Thanks and Good Luck,
Tech Sheet - W10177462A.pdf (530.1 KB)
