Dryer drum roller
I need to replace the drum roller on this dryer and also the shaft that the rollers mount on. Since the shafts are out of stock until May would it be possible to replace the entire roller bracket assembly P/N AP4048635, instead of only replacing the shaft P/N AP4063663?
I do not see why not.
Though something is weird one made by Whirlpool ~$5.00, one made by Speedqueen ~$46.00, this difference seems awful large.
Also the shaft from Whirlpool is as much as the shaft and bracket.
I would call AppliancePartsPros just to be sure it is as illustrated.
