Dryer drum baffle
How does one change a dryer baffle in a drum?
Hello NDR. You will need to disconnect the power to the unit. Then with a flat blade putty or butter knife, release the clips under the front corners of the dryer and raise the top of the dryer. Once raised, you can rotate the drum and remove the screws securing the baffles inside the drum assembly. Reinstall in reverse order. Hope this helps.
AP4009618
Tumbler replacement parts for MAYTAG MDE208DAYW DRYER- ELE | AppliancePartsPros.com
