Dryer Will Come On. But, Only If The Heat Is Not Turned On. If Turned On In A Cycle That Has Heat It Will Turn On For A Split Secound Then Goes Off Immediatly. Can You Help???
Could not find any info on this unit, please check your Model Number
Could it be LEQ2152ES0?
