Dryer Doesnt Heat
i replaced heater coils but not the thermastat but dryer still doesnt heat
Did you check the heating coil or just assume that the coil was the most probable cause?
I am assuming that the dryer ran and the only problem was no heat.
Replacement parts for KENMORE 11067542600 | AppliancePartsPros.com
Could be a number of things but the most likely is a power problem or the thermal fuse on/near the heating coil.
Power Problem:
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!
Thermal Fuse Problem:
It will be on or near the heating coil along with the hi-limit thermostat.
It is the fifth item in the parts list Thermal Cut-off.
It should measure 0 ohms.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil if you still have the old one.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
