I have a Frigidaire Crown dryer and it just started NOT shutting off ~ HELP!
In order to provide most accurate advice we need the complete model number of the dryer and as much description on the problem as possible.
if it happens while the timer is active it is yourdoor switch, put your timer off then open the door and while the door is open turn the timer on if it goes on it is your door switch. let me know if this happens then is can tell you what to do.
