Dryer continues to run
dryer is 18 month old,
it continues to run,heats up and dries the clothes but won’t shut off.
Replacement parts for WHIRLPOOL WED5200VQ1 29" ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
Does the timer advance?
Does it do this in both auto and timed dry modes?
In timed dry the timer motor gets power directly from the line through Timer Switch 0, T/X contacts.
In auto mode the timer motor gets power through the heating coil when the heating coil is shut off by the operating thermostat through Timer Switch 0, T/F contacts. If the heating coil is grounded or for some reason is not turning off then the timer motor never advances.
WED5200.pdf (127.0 KB)
