How much of the machine do I have to dismantal to get the belt over the drum.Need dyagram
You must first remove the top. Then remove the splash plate and the controls. They have quick connects. Remove the rear hatch. Get the front panel off and remove the drum. Clear out the lint and check the glides and the rear bearing. It seems tough but it is not that difficult.
Hi John,
You can use the instructions from the file attached to the reply. You have to read the first three pages only.
If the belt broke, just replace it.
If the belt fell off, inspect the idler pulley.
Removing the heating element - electric dryers.pdf (360.9 KB)
