Drum won't turn
We have replaced the roller wheels and the blower. After putting the dryer back together, the drum won’t turn. Is there any help for me?:o
Make sure the belt has the proper tension.
Nat
Is there any way you are able to explain how to do this? My hubby isn’t exactly a house repairman…we changed the blower wheel, placed a new belt on. It was working fine before we did anything-just made alot of noise. Maybe I should have kept the noise!!!
Here is the drawing of your dryer #5 being the belt. if you notice the loops on the lower right side of the drum that’s where the motor pulley & the idler pulley go.
Hope this helps you some.
Nat
jennair dryer.jpg (45.3 KB)
