Drum Support Roller
I have a LSG7800AAW Stacked Washer/Dryer. The Drum Support Roller is loud. Want to replace. I watched the video and it’s for a stand alone LSG7800. Are the Drum Support Rollers the same for bot Stand alone and Stacked machines? Thanks
Here are your parts.
Parts for Maytag LSG7800AAW Washer Dryer Combo - AppliancePartsPros.com
Yes the rollers are basically the same (item 21 in section 17)
Replace both rollers.
Also check that the roller shafts are not worn/grooved.
