Drum removal
I am unable to remove the drum from the rear tub assembly.
The problem began with clunking and squealing sound. It also didn’t seam to do the final spin cycle clothes came out wet. I found a broken shock absorber. Replaced that and the problem is still there. I began taring down washer, removing the tub assembly and am now stuck with the drum stuck in the rear outer tub assembly. How do I get the drum out from the rear outer tub assembly?
You should not tear into it without a service manual, so here is a link to one from Frigidaire.
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
Sounds like your bearings or spider support may have failed, in which case a new machine is probably the better option.
