Washer & Dryer combo. Frigidare Model gltf1670as0. I ordered a door lock switch and this did not help. I then removed the back and run some test. I have a locked drum and I cannot break it loose. Should I just trash this washer?
Hi Larry,
How did you find it?
Which tests did you run?
Here are the breakdown diagrams and Parts for Frigidaire GLTF1670AS0 Washer - AppliancePartsPros.com
