i have a whirlpool ghw9250mw1 front load washer and it says he drain pipe in your wall must be 30" above bottom of washer, so if you put it on the 14" tall pedestal does that mean the drain pipe in my wall would need to be 44" up from the ground, if so i find it hard to believe anyone has one that tall in their house, mine is like 33" tall, will there be a draining problem, thanks
The problem is that if your drain pipe is too low water will siphone out the machine as it fills and operate.
So, the easy solution to your issue is to try it out, if it works fine, you’re ok.
