Drain impeller
i replaced rubber drain impeller (maytag part #900894) with the gray center up, and the white center down. i didnt take notice when i removed the old one. is this correct? thanks
These two parts have a graphite rings (bearings). The black on one and the white on another one. They must face each other.
Impeller
Part Number: AP397341
Manufacturer’s Number: 900894 made by MAYTAG Our Price: $8.29
Compare at: $15.39
You Save: $7.10
Availability:
In Stock
Order now and it will ship Monday
Quantity
Different views available:
If you are talking about impeller only, then the white part should face down, toward the black graphite ring on the bottom seal.
thanks gene
