Kenmore dishwasher began leaking out of the drain flapper linkage during drain cycles. I changed motor/pump assembly (WD26X10013) When I receive the new unit, I noticed that the drain flapper doesn’t close completely. Pressing the soleniod plunger down, there is about 1" gap between the flapper and where it is supposed to seat. I can press the cam a little further, maybe 1/4" before it hits the mounting bracket that the solenoid is on but it still doesn’t completely seal off the outltlet port.
I’m not seeing any adjustments that can be made on the arm, could this just be a bad unit or is it adjustable?
[COLOR=Blue]I’m not seeing any adjustments that can be made on the arm, could this just be a bad unit or is it adjustable?[/COLOR]
As far as I know there is no adjustment, just the slop in the mounting screws.
Remove the solenoid and check it to be sure the solenoid plunger can be pulled all the way down. Perhaps it is defective.
Also manually actuate the flapper valve linkage to see if that is OK.
I doubt the following is the problem so just mention it in case something strange has occurred. Check that the solenoid has not overheated and melted the plastic inside the plunger area and this is stopping it from closing all the way.
The way this is supposed to work is that at the start of the drain cycle the solenoid receives power for about 10 seconds, the flapper is moved to the drain position and the water pressure hold it there till the unit is empty. If the timer messes up then it gets power for a longer time and it will overheat.
PS: I could not find a full parts breakdown for your unit but usually a leak at the flapper valve arm can be repaired by replacing the seal and it’s push on nut.
Unit appears to be operating properly. Plunger goes all the way in. It can’t really travel any further down, as the cam has reached the end where a straight down pull works (has to now push cam horizontal). I am able to push 1/4" on cam past where plunger has pulled it before it hits the mounting bracket, but the gate still doesn’t seat against the outlet.
I saw this before installing the new unit, but from watching the operation, it appears that the solenoid kicks in for about 5 seconds, just enough time to get the gate into the flow of things and then the pressure seals the outlet.
Even though I can see that there is water discharging out, with the door open, I can see that there is still water bubbling out of the spray arm so that would lead me to believe that it isn’t sealed off, so water can bypass and circulate around instead of being forced out the drain hose. DSCN2982.JPG (36.7 KB)
OK lets take a step backwards, when you originally said
[COLOR=Blue]Kenmore dishwasher began leaking out of the drain flapper linkage during drain cycles.[/COLOR]
Did you mean that it was leaking water out of the flapper seal onto the floor or that the water seemed to be bypassing the wash/drain flapper?
You then replaced tthe pump assembly and nothing has changed?
Is the unit draining properly?
Note it is normal for the unit to leave about a 1/4 inch of water in the bottom of the tub as these pumps will burn up the seals if run while dry.
I went to the sears parts site and looked at the parts breakdown.
It looked suspicious to me as it showed a rear inside the tub screen filter but did not show this as a separate part also it did not show a Piston & Nut assembly.
Here is the Sears link, I am not sure if the site filters will let this through http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=363.14471791
Hey, in a classic home repair conundrum in which I found the ONE person with the same problem as me in a thread from six years ago.
If there is any chance you see this message I am BEGGING you, what did you do to solve it? I have a GE dishwasher that won’t drain, I’ve taken the whole thing apart and there’s no blockage anywhere.
The solonoid doesn’t close the flapper all the way, just like you. Just like you, I bought an entirely new assembly with a solonoid that is fully actuating, but out of the box it just doesn’t close the flap all the way and it’s the only thing I can see as a problem. I dropped $180 on the assembly and I really don’t want to have it go to waste. If you found a solution, please let me know.
Hey. I did end up getting that fixed, but that was 16 years ago and I honestly don’t remember what the final fix was, but I do remember it was very frustrating. We have since replaced that dishwasher, so I can’t even look at it and see what I did… Sorry and good luck.
