Upper Oven Will Not Light. Pilot Light Glows. Upper Broiler Works Fine, As Does The Lower Oven.
[FONT=‘Times New Roman’][COLOR=#000000]The igniter is the most likely cause even if it is glowing. It has got to draw between 3.4 to 3.6 amps to open the gas valve and light. If you don’t have an amp meter to check this replace the igniter because it is most likely your problem. Gas Oven Repair Guide[/COLOR][/FONT]
