Door spring just popped on upper oven door left side. Wont close so light remains on. Is there any special procedure or diagram to remove the door and replace with new spring hinge assembly? Thanks.
Here is the parts breakdown
Replacement parts for JENN-AIR WW30430W Walloven - S/c Ele | AppliancePartsPros.com
Here is a manual which should help
http://www.servicematters.com/maytag_library/docs/16010312.pdf
