Double oven electric range
Wife said temp in both ovens was very uneven. Checked with a probe and found temp off by over 50 degrees both ways.
Tried the standard recalibrate in the user manual, didn’t do anything.
When I unplug and replug the power, a code appears briefly above the time. But it is not an “F” code. It reads: 3.0
What does that mean?
Seems unlikely that both sensors would go bad at the same time so I’m trying to dicide if I should replace the temp sensors before going to the very expensive main unit control board.
Thx much.
[quote=creamean;786488]Wife said temp in both ovens was very uneven. Checked with a probe and found temp off by over 50 degrees both ways.
Thx much.[/quote]
Any ideas?
