Door won't close completely
Oven door won’t close completey. I removed the door and checked both hinges and attachments. All appear straight and operating properly but door still won’t close. I can push it shut but it won’t stay closed. Remains open about one inch.
Hello.
First of all check for any obstructions - door gasket, racks, bottom panel. If everything checks OK most likely the problem is bad hinges and receptacles.
The hinge kit AP3844318
Here are the breakdown diagrams and Replacement parts for Frigidaire FEF364DSA Frigidaire/electric Range | AppliancePartsPros.com
