Machine acts like it is un plugged. I verified that there is power to the machine, but it is dead. When tou pull out the timer switch, it doesn’t even tic. I thought timer, replaced, same problem. There is no inline fuse so I am guessing door switch?
Looking at the wiring diagram, if there is no fuse then the lid switch looks to be your problem. You can use a meter to test it.
