Are there any associated parts that I should order with new springs, or is it just the springs? Common problem I guess - door just falls, no tension.
The door springs ([COLOR=#0066cc]AP2920972[/COLOR]) should solve your problem. Make sure and look for the plastic spring bearings ([COLOR=#800080]AP3010626[/COLOR]) when you install the new springs. If they pop out or are broken, the door with make noise when opened.
