Brian,
Received outer handle and door. Removed old door, hook latch, outer and inner handle, and glass door. Just ordered an inner handle since it was cracked, but the tape was not in stock.
Is the two sided tape special high temperture tape?
Thanks GM.
The tape is just thin foam tape to attach the glass and to reduce noise from vibration so find something non-metallic to use and you should be good.
Brian, only took me 15 minutes to break down the door. Thanks again.
gmeyer555
Glad I could help.
