Door lock light on dishwasher won't run
Brand: Maytag
Model Number: MDB7749SBW1
Main Symptom: Door lock light
What happens & when: I reset the machine and held the door lock button 3 seconds
Hello, are you asking about the control lock? When you hold the lock button, it should lock or unlock the control.
Does notowork. I held for 3 seconds and it stayed on. I turned off the breaker and when turned on the door lock light stayed on
Will you reply again?
In that case, you need to replace the control board, W10595568 Electronic Control Board | Genuine Whirlpool OEM In Stock
Is it possible it is the latch
I replaced the latch and the dishwasher works.
