Door doesn't close all the way
The door does not close all the way, I think that the spacer in the bottom of the door broke. (little black piece), so now the door does not close all the way… Help!!! I want to make sure that I get the right part.
thanks
Hello. There are actually two parts to the cam that causes the door closure. The most common part to give problems is the cam [AP3773514] on the lower door hinge. This part number is the same for both doors. Sometimes the small screw holding this cam in position is at fault and if it is loose, can be tightened. If the screw has fallen out it can be reinstalled. Both of these actions require the removal of the door to access the parts in question. (To prevent personal injury, empty the door before removal).I hope this information was useful and I wish you a great day!
