Already cleaned filter, checked drain hose, Tub to pump hose. How is the pump removed from the back or is there a way to remove the front.
Thanks for your time,
Bob
Bob
Hi.
The pump should be removed from the front.
-open dispenser lid,remove 4 screws, take the lid off, pull down the dispenser.
-use a putty knife to release two clips, holding the top (approx.2.5in at each corner).
-push back and lift the top.
-unscrew the 2 screws from top corners.
-remove the screw from the filter cover.
-use a flat screwdriver to unhook filter cover, pull it out.
-remove 2 screws behind the filter cover.
-open the door and remove the clamp using the flat screwdriver.
-separate the clamp assembly from the front cover.
-tilt the front cover, disconnect the door switch and, lift and separate the front cover.
-remove the hoses and the pump.
Here are the breakdown diagrams and parts for LG WM2010CW - AppliancePartsPros.com
Simon.
