Does someone have a wiring diagram
I have a kenmore model 11060712990 that will not start. I have checked the door switch and tested good.
have voltage at the motor, start switch checks good all the way to the motor I would like to be sure I have a motor failure or the timer is bad it worked fine yesterday and last night wife told me it will not start no odd noises or smells. I would like to see if someone has the diagram for this so I can properly trouble shoot the curcuit for motor start.:slight_smile:
MD, Are you sure you have voltage on the blue wire at the motor ? We’re thinking you may have an “open” thermal fuse
AP6008325
Located on the blower housing. If that component has an “open” circuit, the dryer will not start or run.
Being a Sears/Kenmore labelled product, they are the only establishment with a wiring diagram.
We’re attaching a basic, generic wiring diagram, it may help you out.
Good Luck, and Thanks
[ATTACH]4395[/ATTACH]
Binder1.pdf (233.0 KB)
Thank you! for all the help broken connector on the thermal fuse wire at the motor connection, looks like it is repairable just need to repace that connector. Saved me buying a motor and timer.I hate throughing parts at things wastes time and money. $2.00 is better than $200.00 once again thanks for the drawing.:cool:
MD,
Great, Glad we were able to assist.
Good Luck and Thank You,
