does not spin until play with On/Off Dial
Machine bypasses spin cycle. If I select one of the other spin cycles and try to turn it on 10 or 20 times, I can get it to spin. Will replacing the switch under the dial fix this?
I would try replacing the control unit
[PART]AP4026547[/PART]
and see if that doesn’t fix the problem.
