Do you REALLY need to buy the whole kit for a leak?!
We have a leak at the flange between circ pump and its housing on a SHU9925 Bosch dishwasher.
It seems the only way to get parts for that is to buy the entire kit (AP2802376)
Thanks Gene,
would you recommend to use all teh parts out of the kit?
I assume Bosch put that kit together for a reason.
Is this a typical problem causing leaks into the floor pan?
I’m still not 100 sure that I found the leak. Indicator is sediment around the lower part of the flange.
