I want to replace the pump assembly for my DU927QWDQ1 dishwasher.
I see I need part AP5305918 and the gasket AP2908993.
In the “product question” section after the order page it says “the manufacturer also recommends replacing the relay”. But how do I know what relay that is? Is there a typical relay that would need to be changed when replacing the pump assembly?
I could not find a relay. Also when I did a Search By Keyword a relay did not come up.
So I went looking for a wiring diagram. I could not find a DQ1 but did find a DQ0 which should be a close match (see the attachment) again I do not see a relay so I am stumped perhaps that Question is for a different model.
I would check with the parts people. DU927.pdf (1.4 MB)
Thank you, very helpful! Do you know if I will have to remove the dishwasher from under the counter to replace the pump assembly or does it go in from the top?
Mike
