I need to replace the seals on the drum. The original seals seem to have been glued in place. If I need to glue them what kind of glue do I need? Thanks for your help!!
Hi Scott
Here is the manual Maytag lists for your model. It should answer all your questions and show you what you need to do.
Good luck, and please post how you do.
I couldn’t find the link to the manual for the Maytag dryer. Do you know where I might find it? Thank you so much!
Well, it looks like the link dropped out of post. Probably my fault although I would like to blame it on something else.
http://www.servicematters.com/maytag_library/docs/RS3200007R0.pdf
Let’s try again.
Good luck
