DL (Door Lock) Error Code on Speedqueen washer
Brand: SpeedQueen
Model Number: ATEE9ASP176TW01
Main Symptom: error DL
What happens & when: at startup of wash cycle when door lock is unnsuccesful a DL error code appears
Error Code (if any): DL
Parts or tests already tried: cleaning door
Symptoms were intermittent at first with larger loads and now the error is persistent. I couldn’t find the part for a door lock actuator or something similar to try and replace
Speed Queen 803920 Door Latch/Switch Assembly OEM Part [AP5960286]
Thank you. I will try that!
