Diswhasher - Not Filling / Not Advancing through cycle
No water goes into the dishwasher. When I mannually put water in dishwasher and turn it on it goes into wash cycle and gets stuck there. It will drain if I lift the float in the bottom tray and hold it up. Tested water valve by removing from dishwasher and plugging into outlet (water comes out when I plug it in and stops when it is unplugged). Suggestions?
Check if 120V is coming to the water valve while the control calls for water.
If there is no 120V then the control module has to be replaced.
