Diswasher Leak Bottom Left Door
Small leak on left side of door spilling on ground. Can feel wet insulation behind door panel. Replaced door seal, still leaks. Examined sprayers for cracks, and they look ok. Float level moves up and down. Removed door panel and saw evidence of leak around vent assembly inside door. Ran rinse cycle with panel off. Saw drips coming from vent assembly, but clinging to door. Although leaky, my guess is that it drains inside tub anyway. Should the vent assembly still be replaced? Saw lots of water coming through air vent at bottom of tub, filling back end of tub. Doesn’t spill over though. Is water supposed to go through the air vent? Seems like it fills the whole front side of the tub inside the door area to about half way to the edge of the tub. Is this normal.
Wife says after filling soap dispenser she adds extra soap to bottom of tub. I heard this may cause excessive sudsing and water to spill over edge of tub. Your help is appreciated- thank you.
Hey if you get an answer somewhere about how to fix this let me know.
