I own a Neptune MAH7500AWW s/n A5799196CT. The display is starting to go out. Sometimes it will blink every one to two seconds. Other times it is dark. Once in a while it will work after I touch the lower left corner. Other times it works after I unplug the the washer for a few minutes then plug it back in. I know it’s a matter of time before it quits for good.
Does anyone know what the problem is and where I can get the part?
You would need the LCD Control board. Here is your part # 22004317. It is east to replace. Just take the back off the control panel, and it looks like for screws, and some plug ins, and you got it. You might want to unplug the washer, and take the back control panel off, and take off, one wire at a time, and put it back on. Also do it with any harness on the Board. You could just have a loose or poor connection. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
It does sound like a dirty or bad connection somewhere.
Looking at the price I would try the following on all connections to the board.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
I would also check it for a cold/bad solder joints and bad crimps etc. on the plugs.
Cold solder joints are often a duller gray or have pin holes.
Also sometimes if you wiggle the component you will see the components leg move on the solder side.
A magnifying glass is a big help here.
I have a Maytag Neptune washer MAH7500aww and dryer MDE7500AYW that have similar problems only when the temperature drops below 60’ish. If I put a heating pad on the control panel for a minute it will respond again. Is your control panel only acting up in cool weather.
[QUOTE=LauraB;640899]I have a Maytag Neptune washer MAH7500aww and dryer MDE7500AYW that have similar problems only when the temperature drops below 60’ish. If I put a heating pad on the control panel for a minute it will respond again. Is your control panel only acting up in cool weather.[/QUOTE]
I have this same problem. I can take the control console off and use a hair dryer to warm the electronics board.
Does anyone have a comment on this? It seems this may be a common weak design with this unit.
