Display Panel not working
Brand:Whirlpool
Model Number:WRS571CIHZ004
Main Symptom:Display Panel dark/not working
What happens & when:Recently
Error Code (if any): None
Parts or tests already tried: Replaced the Display Panel and still not working. Replaced the main control board twice, everytime the new board caused the Refrigerator to stop working.
Hi tran92708,
I would start by checking these few things:
  • Pinched or frayed door hinge wires: On many side-by-side refrigerators, the wiring harness can fatigue and break where it passes through the bottom or top freezer door hinge. This can cause intermittent shorts and a variety of electrical issues.
  • Incorrect control board programming: If the control board has been replaced, make sure it has been programmed with the correct 4-digit code from the serial sticker on the cabinet frame. An incorrectly programmed board can cause unexpected operation.
  • Unstable wall voltage: Voltage spikes or a poor neutral/ground connection can damage the sensitive electronics on the control board. If possible, verify that the outlet is supplying a stable 120 VAC and that the wiring is in good condition.
Where can I find the 4 digits code?
Hi tran92708,
You should have received a programming card with the replacement control board. That card contains the correct code that needs to be entered based on your model number. If the board wasn’t programmed with the correct code during installation, it can cause the refrigerator to behave unexpectedly or not operate correctly.
There are no card.
The board PN# W11606656.
If no programming card was included with the replacement control board, then this version of the board likely does not require any additional programming.
Have you tested the control board yet? If so, what readings are you getting at the main board?
If you’re not sure which test points to check, let me know. I can provide the test point locations and walk you through the voltage checks step by step.
No. I have 2 new boards from Appliance Parts, I tried both of them and the refrigerator stop working when I put the new board in.
hi is the new board installed now ?
No. I took it off and put back the old board because it caused to refrigerator from running/nothing work.
