Display on washer has no power
Brand:GE
**Model Number:**GFW850SSN3WW
Main Symptom: Cannot operate washer
What happens & when: When I put power to it there is no display and it sounds like the pump is on.
Does it sound like there is clicking around the top left side of the washer, and if there is, how many seconds are in between each click? If there is no clicking, a voltage test can be done to identify what might be occurring. On the main control, there will be a 4 wire harness connector on connection J615. With a meter set to DC voltage, the black meter probe can be placed on the red wire at pin 4 and it will stay there for testing purposes. The red meter probe can be placed on the black wire at pin 8, where it should read 13.5 Volts DC. The red probe can then be moved to the yellow wire at pin 2 (data transfer wire) where there should be a DC voltage that fluctuates. The red probe can then be moved to the blue wire at pin 3 (data received wire) where there should be a fluctuating DC voltage if the user interface control is sending communication signal back to the main control. Are any of the voltages missing?
User interface control- WH22X34919 Washer User Interface Control Board | Genuine Ge OEM In Stock
Main control- WH22X37840 Washer Main Control Board | Genuine Ge OEM In Stock
