Dispenser cup full of water
I have an LG front load washer that the dispenser cup when wash is completed has standing water in more than 1 of the cup areas. I have cleaned the cup and made sure that there is no residual buildup (spotless). I have verified that the all the valves have continuity with 2 meters. Any ideas cause I am at a loss.::confused:
The best guess here is that there is some grit or somthing that keeps the valves from closing completely when the cycle is over. Try replacing the valve assembly and see if that does not fix things.
