Dishwasher
Lights on the panel come on but the dishwasher will not start. If we flip the circuit breaker it will start even though the breaker was not off.
I cannot find any info on the given model number.
Tried here and the Whirlpool site.
Please check it.
Sounds like a control board problem.
The4 microprocessor is not resetting by itself but when you remove power from the unit then you manually reset it.
That may be a zero instead of an O on the model number. If it is the control board does that mean we would have to replace the whole board and what would be the cost?
Already tried a zero.
Sorry, the model is KUDSO3FTSS2
Parts for Whirlpool KUDS03FTSS2 Dishwasher - AppliancePartsPros.com
I am assuming that everything looks normal after a cycle other than you cannot start another cycle.
Look through the tech sheet in case anything listed there comes up.
if all OK I would replace the control board (item 6 in Control Panel Parts section)
KUDS03.pdf (86.9 KB)
Thank you for your help Denman. The PDF wouldn’t open but I will check out the control board. That is what we expected.
I do not know what happened with the tech sheet so here is another try at attaching it.
KUDS03.pdf (244.3 KB)
