Spring in the soap dispenser slide door has come off and I would like to reconnect it to the slide door.
The instructions are attached to the reply.
Replacing dispenser doors and springs.pdf (131.2 KB)
I do not believe that I have ever had a more frustrating experience in attempting to retrieve information. Why doesn’t the info come through without contacting NASA then going to Disney?
I truly give up, Moerke:)
[quote=Gene;747962]The instructions are attached to the reply.
Gene.[/quote]
Gene how do I take the sliding soap dispenser door off to re-engage the spring, my model number is SHU3032
Thx
Carefully pull the lid up on one side to release it from the rail.
Thx for your help Gene
You are welcome.
gene.
