dishwasher will only drain half the water out
Stoney, A few things to check first. Remove and check the filter
AP3187339 for debris and hard water or detergent deposits.
Remove the sump cover/filter AP4484685 check those for the same, and look and carefully feel inside the sump and clear it out as well. Disconnect the drain hose from the disposal or sink drain connection and drain the dishwasher into a bucket, this will clear most of the debris in the drain system. If the problem persists, you’ll need to dismantle the pump assembly and check the impellers for damage.
Thanks,
