Dishwasher
leakes water at bottom left side.i changed gasket#154845301&ap4421139 & water still leaks.i noticed that there is a gasket on left top of door ap2108939 &ap2109282&ap2108981 do they have any thing to do with the leaking.the ones that were their are gone they were melted from the heat.
You may want to replace the bottom door gasket. This gasket has been changed by the manufacturer, adding side seals that restrict the water surge from the center spray arm.
This seal can be replaced without removing the dishwasher or either of the door panels. The seal is located on the bottom of the inner door panel and appears as a cream colored flexible rubber blade bonded to a milky white colored plastic strip. To remove and properly install replacement follow the instructions carefully.
  1. Replacing this seal can be accomplished without disconnecting power from the unit. Always use extra care when electrical power is present while serving an appliance.
  2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
  3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the seal can be pulled down slightly to facilitate removal.
  4. Pull seal straight into the tub from right side.
  5. With seal removed, and before installing replacement seal, locate the channel in inner door panel that the seal mounts into. Locating this channel before installing the replacement can make this procedure easier.
  6. Place the new seal on a flat surface and measure from the bottom of the seal up 3/8 "of an inch and place a mark with a pen or marker on both ends. If needed, scribe a straight line between these two marks this
    will give you a guide when installing seal into the inner door panel.
  7. The seal can only be installed one way. The end that holds this seal into the inner door panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed around the end of the inner door channel that holds the seal.
  8. Line up the seal along the bottom of the inner door panel and start from the right side, push the seal into the door channel to the line marked in step #6.
  9. With seal in place close the door, the tub will align the seal as needed.
  10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit for dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on both ends. This locates how far down the seal needs to be before closing the door. Do not install this seal without measuring it first. After the lower door seal has been re-installed then install the splash shields according to the instructions accompanying with the kit.
