Dishwasher
Normal cycle on control panel is frozen. Other buttons work.
What part do I need to replace?
Here your parts
Replacement parts for FRIGIDAIRE PLD2850RDC0 Frigidaire/dishwasher | AppliancePartsPros.com
Not sure what you mean by frozen.
Frigidaire does not publish the pin outs for the keypad so try the following cleaning/check.
If that does nothing then I would probably change out the keypad first.
Unfortunately it is a crap shoot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
